I have an 81 caballero with an automatic transmission I think it is low on fluid how do I check and add some if it is low?
Start with putting in 4 quarts. Start the engine and let it idle in park and check the level. Shift through the gears (foot on brake) and recheck. Don't overfill.How much fluid should I need if I drain the pan and change the filter?
