you can hide it I guess....personally I would leave it available so if you ever need it it's there
ok sounds good to me thankspontiacgp said:you can hide it I guess....personally I would leave it available so if you ever need it it's there
pontiacgp said:googled = you only need to retain the "BAT" wire. The #1 & #2 terminal wires can be eliminated. Don't be surprised to find that the #2 wire only goes a short way into the harness and spliced into the "BAT" wire.
You'll probaly want to keep the #1 wire tho for your warning lite or gauge
liquidh8 said:pontiacgp said:googled = you only need to retain the "BAT" wire. The #1 & #2 terminal wires can be eliminated. Don't be surprised to find that the #2 wire only goes a short way into the harness and spliced into the "BAT" wire.
The one wire needs a small voltage to excite it, if it doesn't get it, it'll never start to charge. If you just run bat voltage to it, it'll burn up the alternator. When you have the idiot light/guage, it it hooked up to the excite wire of the alt so when you start the car, the field wire gets switched 12vdc, and the excite get a small voltage, and the alt starts putting out. thats why you need a self exciting voltage regulator to just run on wire.
IMO, keep it stock and get a bigger alternator, they are made by all sorts of people.
