This thread is for those of you who are wanting to detail your G Body exterior or any vehicle for that matter that needs to be detailed for the very first time and then maintained afterwards. First I want to say that I am NOT RESPONSIBLE for any damage you do to your vehicle. Second, if you recently had your vehicle painted then I recommend waiting at least 90 day's before applying any wax or sealant to the paint job as to let the paint cure and gas off (ISO's). This entire thread or article is all based on my opinions and what materials I personally like to use. I have tested a TON of different brands of polishes, equipment, waxes, etc and use what I have found to be some of the best or top of the line and easiest products out there.
I will do to the best of my ability to make this organized and in order while still going into partially deep detail. Let's start with materials list, where to buy these materials and add a link next to the uncommon materials that some may not even know about...
Materials:
1.) Variable Speed Buffer (DeWalt, Makita, Porter Cable, etc)
2.) Buffing pad cleaner, brush or pad spur
3.) 6.5" Wool/Foam blend cutting pad (Lake Country brand)
4.) Medium (white color) Polishing pad (Lake Country brand)
5.) Light Finishing (grey color) pad (Lake Country brand)
6.) Microfiber towels, cloths, wash mitts and hand applicators
7.) Compound (Optimum Car Care)
8.) Polish/Swirl Remover (Optimum Car Care)
9.) Finish Polish or Polish/Paint Sealant (Optimum Car Care)
10.) Paint Sealant (Optimum Car Care)
11.) Spray Wax (Optimum Car Care)
12.) Clay Bar (Obsessive Detail brand)
13.) 3M painters tape (I prefer the green kind but blue works too)
14.) Dawn Soap
15.) ONR Optimum No Rinse (Optimum Car Care)
Here is the basic material list you will need. Again the brands I prefer are what I put above. You can go with any brand you want and any priced buffer you'd like just remember to follow the exact instructions on the bottle.
The only places to get Optimum Car Care products is through their site directly www.optimumcarcare.com or I always go through www.obsessivedetail.com and order everything. For microfiber towels and cloths I get them from Obsessive Detail or the sister company www.theragshack.com or even www.towelpros.com
I recommend using microfiber cloths only to do the washing, drying and cleaning of your vehicle inside and out!!!
I use almost all Optimum Car Car products and the reason is because they last a long time, easy to apply, and no dusting with their compounds and polishes like 3M does. You can also work with this stuff in the sun. Now 3M does make a good swirl remover called UltraFina, I like to use this on black vehicles and certain types of paint.
*Tip* Try this before starting anything... Take a plastic bag, put it over your hand and rub it over your paint surface. When you are all done with this entire paint care process, do it again and you will feel a huge difference if done right and your rags should float right off that hood or roof.
Before Getting Started:
Before you even think about pulling out that buffer there are a few things that need to be understood and done to the car. This article is about paint care and is for those who are doing this for the first time (not touching up a previous detail job). The first thing you need to know is, why even care for your vehicles paint and what exactly are you doing to the paint when buffing?
To answer the first question of why is because keeping up with the exterior paint will keep your vehicle looking great without ruining the paint from road grime, salt on the roads, bugs, UV from the sun. It keeps the vehicle cleaner for longer periods of time, makes it easier to clean the next time you wash your vehicle and will even add value to your vehicle. To answer the second question as to what you are doing to the paint when buffing, you are actually removing contaminants from the paint surface and pores. You do not want to wax or polish over a paint surface that has contaminants buried into your finish. You are also removing any scratches and swirl marks that were left from normal road grime, wear and tear, improper washing (yes there is a method to just washing a vehicle which I will touch on in another thread), and previous improper buffing/polishing techniques.
Now that you know the why's and what's of exterior paint care, we can get started on the process of how to achieve a great looking finish!
Materials:
14.) Dawn Soap
