the "frame" itself can be disquised/grinded down,and clean up by a good "cover-up artist"
check the front upper a-arms,see if they were cut out to accept the cylinders and also check the trunk "shelf" as there would be cutout's also for the rear cylinders.also give attention to the lower spring parches on the rearend,as some opt to cut this off and build a enclosure for the "ball joint" assembly.if you have suspision as to the cutty having being juiced,id say pass and wait for another? as a lo-lo NOT done right,(99% propability,UNLESS its from the L.And that invented them :wink: )can be a horrible expirience when it come's to trying to restore it back to the original cond.
