Hpw many belts are there on a 86 5.0 307 olds?
86laidlow
31
I am going to change the belts on my 86 regal 5.0 307 and the ****ing autozone gave me 5 ****ing belts,but i only see 4? :? Is there really five?and if yes what are they?also whats the easiest way to remove and replace them?
Well, there should be four I believe...
One that goes around the crank, water pump, and alt.
One that goes around the crank, water pump, and P/S.
One that goes around the crank, water pump, and A/C.
And one that goes around the crank and air pump if it's still there...
As for the easiest way to take them off, cut them.
However to get them back on, you're still going to have to loosen up each component and fish the new belts on one at a time in the correct order.
One word of wisdom, don't pry against the p/s resevoir while you're tightening the belt unless you want to replace it after you poke a hole in it.
