Is there no table you can manipulate to stop this from happening?
Okay here is why this thread above is so significant. I was chasing an issue with the propane injection system on my TBSS for a few months, so during that phase I turned it off and tuned it out. Keep in mind that the propane system acts as a 9th injector and adds about 20% additional fuel to the engine - which reduces the demands on Injector Duty Cycle (IDC). Unbeknownst to me at the time I built this truck that this system was saving my *ss in more ways than one. Long and short of it is that without the ability to turn off Brake Torque Management (BTM) in HP Tuners (only available in EFI Live) the truck was bandaided by this additional fuel as it altered/lowered the calculated torque. When BTM kicks in it pulled over 10* of timing, to the point there was negative timing under load/at WOT and IDC is 94% - calculated torque flat-lines at 738ft/lbs. This effectively causes the truck to fall flat on it's face.
Now let's turn the propane injection back on. IDC drops by 22%, spark stays as programmed, and calculated torque is 200ft/lbs lower; and the engine revs out naturally. It is important to note that the MAF is reading much lower (again a consistent 20% error) with the supplemental fuel system activated - this is where the torque calculation comes from. So the reality is the engine is flowing 4800lb/h, not 3800lb/h.
Thanks for the help, HP Tuners.
