i start the car today...and it has a miss. when i rev it it acts as though it has a miss. at idle the engine runs fine but if i stab the pedal hard i get what sounds like a miss.
im thinking i have a fuel problem. AFAIK all lines are fine, i even fixed the one running from the fuel pump to the carb. its not leaking, i checked it. i didnt check all the way back to the tank but it if was leaking i'd smell it.
it might be that the gas is stale but...this wasnt happening last week. it just seems to be lacking power when i rev it but runs fine at idle. in fact it runs fine at any RPM if i dont stab the pedal.
i plan on changing the fuel filter and see if that helps, ive looked in the tank before and that thing is clean as a whistle inside. i might also run some fuel system cleaner of some sort to help get rid of any build up it might be getting from running the stale gas.
