pull steering wheel. remove locking plate, you can rent tool from auto supply house to compress plate, there is a spring type ring on shaft, (note there is an aligment slot on locking plate when you put it back on). spring can be removed with screw drivers. remove screw holding turn signal indicator, there are three screws holding turn signal mechanisam, remove emergency flasher switch. you may have to remove buzzer actuator, be careful not to loose black spring that holds it in. there should be a screw that holds switch in.
