If your going to run the C5 setup then you will need to either run a larger rim with the Torque Thrusts or buy different rims. 17" Torque Thrusts won't clear the calipers.
lemkerailroad said:QUOTE:
so on the front i should run +1.5 off set and on the rear i should run +1.5 off set as well
as far as the torque thrust rims........i was told that these would work???????
FE3X CLONE said:lemkerailroad said:QUOTE:
What you want is to order a wheel based on its backspacing. The term offset is purely the distance from the hub mounting face of the wheel to the actual centerline of the wheel. This will change based on the wheel width and backspacing.
Backspacing is the measurement taken from the face of the hub mounting surface to the wheel lip.
Our cars and most older RWD vehicles will take a negative offset wheel. Positive offset wheel are like what you see on modern cars. Corvette, F-body, FWD cars, etc.
Work for what? They will fit a G-body fine as long as you order the correct backspacing, etc. The issue I was talking about earlier is that you can't run the larger C5 13" brakes with a Torque thrust wheel.
The issue is how American Racing designed the wheel itself. One issue is that the caliper will actually hit the inside diameter of the rim. The reason for this is that even though they are 17" in diameter, there is a 1/2" lip on the backside of the rim that reduces down the diameter. Essentially giving you just 16" of clearance instead of the 17" you thought you had.
The other issue is due to interference with the face of the caliper and the backside of the wheel spokes. The spokes start to curve in drastically towards the center of the wheel where they attach to the rim hoop. No amount of grinding on the caliper will clear this.
The solution (albeit temporary in my case) was to use my existing C5 calipers and run the smaller F-body 12" front rotor. This pulls the caliper down and away from the wheel giving the clearance that is needed. But your stuck with the smaller brake rotor size. 🙁
This is about the best picture I have showing the caliper clearance. This is with the 12" brake rotor instead of the C5 13". You can see it's pretty tight even with the 12" rotor setup:
