Im doing it! C5 Brakes
For mine I just took the stock spindle and cut the stock caliper mounting ears off, drilled and tapped the dust sheild mounting holes out to 7/16-20 and then bought a pair of caliper brackets from www.flynbye.com
I originally took two old brake rotors and had the rotor surface removed on a lathe making them just hubs. But ended up buying billet aluminum hubs through Kore3.
Other than that I pretty much have the same setup as bigblockfrank above. My rear setup is bolted to a Ford 9" which had the correct housing ends for these brakes so I didn't have to drill and cut the stock housing flange. Be aware that 17" American Racing TTII style wheels WILL NOT fit a 13" rotor.
Modified stock spindle with C5 bracket:
Rear LS1 mounting bracket and E-brake:
I also used the stock G-body E-brake cables and just made a couple of mounting brackets:
Did you have to do any thing to the 9" axle flange to fit the rotors over them? I'm doing a 9" swap as well when i get the cash. I like how you have the E Brake hooked up looks like its suppose to be there! as for the front I'm gonna stick with the Blazer spindle swap. so stay away from the AR wheels if i run 17s?
FE3X CLONE said:
For mine I just took the stock spindle and cut the stock caliper mounting ears off, drilled and tapped the dust sheild mounting holes out to 7/16-20 and then bought a pair of caliper brackets from http://www.flynbye.com
I didn't have to do anything to the 9" flange. I ordered the housing and axle package from Quick Performance and paid another $75 to have billet axle flanges welded on that allow these brakes to bolt up.
The one thing that I would do differently if I was to do it over again would be to order the rear housing a little wider possibly so that the shocks wouldn't have to be relocated. But, I already had my rear wheel back spacing setup for the stock G-body width and didn't want to change.
And yes, 17" AR wheels will not fit the front C5 brakes. I actually had to buy another caliper bracket and then downsized to the 12" LS1 front rotor so that I could get everything to fit.
You can see how tight they are even with the 12" rotor:
hmmm but other brand 17s fit the 13 inch rotor?
You'll have to check. It all depends on how they designed the wheel.
okay well i work at a tire shop so shod be able to see what fits when time comes to it. as of now im running 14s on stock tires. just so i dont waste money. im gonna start getting all the stuff together and put together then when im ready all i gotta do is pop the old one out and put the new one in its place
I learned the hard way with the C5 set-up. I purchased some used 17" Torque Thrust that I couldn't use. I had to up grade to 18" wheels. The wheels didnt go to waste....I bought another Malibu.
Hmmmm decisions decisions. if i go with 18 inch wheel i might put the 13.4 inch rotor on it then. would only move the caliper out .25 of an inch more. any one had fitment problems with an 18 inch wheel?
for the ford9 i bought the kore 3 kit, pricey but worth it to me to have the c6 z06 setup matching the front
