jae said:Ok, you're saying the paint is sanding off but the rust is not. Even a wire wheel is not getting the rust off. May I ask the "grade" of the wire wheel, is it soft, medium, hard / aggressively stiff? If you're using a very soft bristle it's not going to get any heavy rust off, you will have to get a a heavier grade and lots of elbow grease.
Else blast.
x2565bbchevy said:Once you get it cleaned up to your satisfaction why don't you just POR15 it when you are done to protect it from rusting any further and later on if you want to really detail it pull the rear end and get it sand blasted.
307 Regal said:If it's chunks of rust, did you try a hammer and a chisel? I had to do that with my bumper shells. Huge flakes of rust on the back side. You would basically be hammering and breaking off the un-saveable metal instead of having to sand all the way through it.
