I'm trying to find these plastic rear glass molding stops there is ( 3 ) of them
Jmac
45
11
McKees Rocks Pa.
These plastic stops fit at the bottom of the rear glass for the rear panel to rest on I'm hoping somebody can give me some kind of direction or a part # if possible help if you can Thank You
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Standby, I have a few extra on hand. I usually pull them from junk cars if the condition is good. Not sure if they have part numbers on them.
85ss/85gn
289
255
beaver dam,wi
Part # 20655818
8,221
17,665
Part # 20655818
Yup. 3 per car. Found on every G47 Olds from 81-88. Not a high wear item. You would think that you should be able to find them at least used nearly anywhere. Saw a set of 11 of them on fleabay a while back.
Jmac
45
11
McKees Rocks Pa.
Thanks for your help they were still listed on ebay I had no choice I ordered them
