Installing Buckets with center console
i bought brackets off ebay 3 in all. 2 for shifter and 1 for the console. my son welded them in place
and the result dual gate
Evan's 85 said:
-83MONTESS- said:
Evan's 85 said:
you will also need the seat belts for the bucket seats, as they are different.
Im using the stock split bench seat belts with my buckets just fine
THEY ARE TOTALLY DIFFERENT AND THE OTHERS LOOK MUCH BETTER/ORIGINAL...JMO
They may look better changed but they work just fine. You can cut the 2 ends off you don't need. Beats tring to get those bolts out at the junkyad rust welded to the floor. I put 2000 cop car impala buckets in my monte carlo. Seats are way firm now.
I finished the center console install with the parts from gbodyparts.com and the results were fantastic.
Reactions: Emmanuel cuellar
Looks great.
Please post pictures of the cable install, where you drilled the hole for the cable in the trans tunnel and finally hook-up of the cable to the trans linkage.
Thanks
Lookin good! So, was my dad and I's console bracket diagram helpful? Dad was very impressed that ya liked it so much and that Brian was considering putting it on the gbody parts page.
xcookpac said:
Looks great.
Thanks
If you look at the last picture you will see a black dot. This is where I drilled the hole. Many say there is one dimple to mark where to drill at. On my 81, there were 3 so I used a diagram that evans85 had drawn up for me to determine that the center dimple was the one to use. I have the transmission getting finished today so after it is done I will take pictures of the cable install to the trans. Here is one picture of the cable routing from above. Not a great pic, but you can see where it went through the floor board.
Extremely helpful to the point if I did not have I may have made a critical mistake. Gbody plans on a tech section with images from my install to help others with your schematic.
Glad it helped. good deal. I believe a tech section would be great.
Evan,
Please send Bweavy a PM with your full name so he can give you props on his website.
