Qwick fix would be using the same stuff you can patch a gas tank with.
How do we go about looking for the R.A. discount code? I scrolled to the bottom of this page and did not see RA as one of our sponsors.
And it's in this thread...They put it in the gbody parts for sale section. I use it anytime I order.
You can flare new ones yourself, or buy them pre made.I'm making progress, i was able to remove the fuel line.
Now the hunt to find a replacement line!!
i’m going to try find a pre bent , or maybe some luck at a junkyardYou can flare new ones yourself, or buy them pre made.
I would try making your own, that way you save money and can also do other things too like brakes etc.
If you are going pre made, I suggest new because you have no clue what's been ran through used fuel lines, and some may have leaks.i’m going to try find a pre bent , or maybe some luck at a junkyard
true, thanks for the tip!If you are going pre made, I suggest new because you have no clue what's been ran through used fuel lines, and some may have leaks.
