I have seen other guys do it on TV. So I know it can be done but can some one run down the steps to removing the Front Cap on a G-Body? Just to make sure we are all on the same topic. I am talking about what it takes to remove the HOOD, Fenders, and Grille as a unit.
It makes doing a motor swap a Whole lot easier this way. Especially if you are planning on maybe removing the Air Conditioning box or maybe doing some suspension work around the same time as the motor swap. I realize you are gonna need a few friends to help with the lifting , but what I don't know is the exact location of the essential bolts that are needed to be removed without disassembeling each piece seperately. Thanks guys.( Maybe this info is somewhere on the web, but I havn't seen it here as a step by step process.)
