CUTLASS intake numbers
oldolds
239
76
pine city/rosaila washington
my 1980 olds originally had a 307 put in but the privious owner put in a 350 olds everything is ok but the vacume lines are missing and some of the vacume switches are not looking like the diagram for any 1980 engines i have seen. where do i find out the year and system i have i tried looking up the number that is cast on the intake but i haven't found any for olds are they the same for chev?
8,827
7,780
It is probably a #16 iron intake. What number heads are on the motor? Is it the original computer controlled carb and distributor?
oldolds
239
76
the dist has the extra terminal for the timing advance and a non computer controlled carb. the intake looks aluminum the extra terminal goes to a vacume sensor that adjusts the timing
8,827
7,780
Probably a late 70's Olds 350.
jetsetw31
678
67
Petersburg, VA
What number heads do you have? That tells a lot about the engine considering it's not a mismatched motor. (Example: 75 block, 70 heads, and 77 intake.)
