Well it would seem that last weekends rebuilding of the seat tracks was a waste of time. Got out to the shop this Saturday morning and was sitting there pondering when I noticed the seat tracks still mounted to the seats I trial fitted in the car a couple of months ago. How can this be, I just spent last Saturday rebuilding a set of adjusters I thought were the pieces I was using. Turns out, they were the pair that came with the purchase of the seats. Not that this is any news flash, Camaro adjusters don't work on stock G-Body mounts. Well then, I have a nice pair to sell when I start selling off the left overs.
Chances are you're probably not going to totally disassemble your seat adjusters to paint them but I did. Be that as it may, I thought I'd share a couple of my make it easier tools with the group. This is my gadget for painting small springs. It's just a couple of threaded rods with nuts through pieces of shelving angle with lots of holes. In my opinion, the only good way to paint a spring is with it in it's loaded / tensioned mode other wise you just paint the surface of the relaxed coiled. As soon as you put tension on it, all the places that weren't painted show. The idea of the threaded rod is so you can adjust for different lengths of springs. I have a larger version of this also. The trick is don't be in a hurry, stretch the springs out and paint. Make sure to cover front back and sides. Leave them stretched out to dry for at least forty-eight hours. This is the way they're going to be on the car so what you see is what you get.
So, I probably need to set the record straight on the choice of colors for my seat springs. Honestly, the new OE springs come the color of a coated spring, usually medium to dark gray. The manufacturer then sprays a blob of color on the end of the spring to identify the application. These colors are referenced in the parts catalog. However, since this isn't a numbers matching car where it really matters, and the fact I glass beaded all the springs raw, I needed to paint them so I just painted them the color the parts catalog references. Yes, they should be a gray color with a blob of yellow or a blob or red. Mine are all red and all yellow. The yellow springs are for the adjuster levers, the red springs connect one adjuster to the other side under the seat.
I paint small parts in a little paint booth I made specifically for small parts. This used to be some kind of medical appliance but I saw right through it's disguise. This giddyup has a turntable for larger parts and also has a 7/16 threaded rod running though it to hang parts from. It has an updraft fan that sucks the fumes and paint out into and through a cheap filter I change once in a while. I use "S" hooks made from wire coat hangers. The flood lights give the metal a good painting temperature and helps the paint flash over. Once the parts are painted, I take them outside and hang them on my drying tree.
This is my high dollar curing oven (drying tree). I carry the parts from the paint booth to the tree using the hooks and hang them essentially the same way with the same hooks. In my opinion, Natural Sunlight is the best drying lamp available. Depending on the circumstances, I leave parts hanging the entire week I'm gone and take them in when I return. A couple of days they're dry, if it rains no biggy.
So, what did we learn today; Make sure you're working on the right parts.
:arrow: :arrow: :arrow:
