is a knocking vortec 350 worth 100 bucks
Buy it! The heads are worth that alone. If you do plan to rebuild it, keep in mind the rings are quite expensive for it.
I would buy it! If the block and heads are salvageable then you're ahead of the game 8) The block is a roller cam and depending whether you keeping it fuel injected or not it's definitely a upgrade! With a good cam you could easily have around 300-400 hp depending on your emission standards.
if i get it i am considering keeping it fuel injected. is there any difference for a rebuild kit between this vortec and and say a standard 80's model 350? i ask because it was mentioned in this thread that the rings will cost some cash. thanks
definitely keep the EFI, it may not be an LS system but it's still a good one. you may want to get a new ecu if you do a lot of performance upgrades, the stock one probably is not reprogrammable. IIRC the newer mk4 ecu is fully programmable, plus there's aftermarket like FAST.
get it and strock it a 383 with vortec heads a 750 carb =about 400 hp DO IT 😛
