To close up this thread, I located the 1st cylinder (frontmost on passenger side. Passenger side is 1 2 3 4 and driver's is 5 6 7 8. Weird huh?) aligned the rotor (points distributor btw) with the terminal for the #1 spark plug wire when the piston was just about at TDC. It helps to have one person inside bumping starter and another with finger over (not in 😛) the plug hole. Looked at the balancer, it was right on 30 degrees BTDC. Moved it a smidge to 15 degrees BTDC, (rotating it clockwise, pushing down on the ratchet) positioned the canister in the middle like I had it, put the dist. in, and it pops off nicely. Revs up better too. Now to fix that pesky donut gasket on the exhausts. 😀 Sorry for the over explanation, just wanted to put all the info outthere incase anyone else on here with a Ford 385 series needs help lol.
