The title pretty much says it all. I have a 168 tooth flexplate on my 383. Will the stock starter off my 305 work on my 383 with 168 tooth flexplate.
82bonne said:im pretty sure i bought a 168 tooth flexplate, but i want to be sure. How can i check if its a 153 or 168 if its already in the car without pulling the trans.
sounds like you need to shim it82bonne said:the starter from the 305 has the staggerd bolt pattern, and it will turn the flexplate, but it grinds. i havent tried the straight bolt pattern starter. Im thinking about just spending the money and buy a mini starter that will work with both flexplates
