was curious if this was just a different crankshaft in the 455 and bored like usual? Didnt know what they were talking about with the different bore numbers. If its just a different crank is everything else for the 455 the same parts that ud normally use? Kinda interested in using a combo like this for my street/strip cutlass if its not more hassle than building up my regular 455 thats bored to a 461.
DMR-5467-S Crankshaft Assy 488-511 Forged Steel
DMR-5467-S (Pictured with all parts coated - NOT INCLUDED) This 488-511 cu in crankshaft assembly can be used in a 425 or 455 block. Kit comes with a factory forged steel crank (balanced, cross drilled and chamfered), rod bearings, drilled main bearings, DMR-5455 7" billet rods by Oliver, Diamond custom pistons (any bore and ring combination made to your specifications), moly file fit rings for proper seal and less drag, new SFI damper and bolt, new SFI flexplate, ARP flexplate bolts, and freeze plug kit. This kit is intended for hard street to all out race use. Use with DMR-5943 billet main bearing caps and a girdle (22360-2, 22361-2, 22362-2) for the highest torque, baddest, and strongest race engine available.
4.155 bore = 488 cu in
4.185 bore = 496 cu in
4.214 boee = 503 ci in
4.250 bore = 511 ci in
