Is there a way to test the oil pressure gauge?
I'd like to try pulling the needle out and see if I can reset it 180 degrees...not sure if that is possible.........
The Oil Pressure gauge comes attached to the Volt Meter that's why I am trying to get this to work.
The wire may have a short in it coming off the sensor
I have an electric gauge that pegs "max" when the ground comes loose
Call off the hounds.............I found a section on the circuit board that was compromised and when I traced the line it
was one to the oil pressure gauge. I peeled back the plastic covering to expose the 2 copper wires, soldered a small
section and VOILA!!!!!!!!!!!!!!!!!!!!! Gauge works............................thank you Lord...............
Thanks to all...........sorry I didn't think of the circuit board earlier but it seemed fine. It wasn't until I truly looked
and followed the path that I found the break.......................
The sweet smell of success..................it never gets old...................
Great, now it's stuck on 40
