Man, I would never have thought about that high-tech solution.they unplug and plug it back in to see if that cures the issue,
I think jeeps suck. But you knew that.
It is working now so I think the wiring is the problem. If twisting the external wiring doesn't affect it then it is possible the internal wiring is faulty. The connector plug wiring inside the case can get loose/cruddy and if you open it you can re-solder it for an easy fix. The "BATT" terminals on all brands are famous for breaking inside when people over-tighten the nut and twist the stud. Then the wire inside gets stressed or breaks.
Or, just buy a new alternator?
