Just GUNK'd the motor, now it won't start
maybe you liquid locked the motor. just let the water drain pass the rings into the crankcase. should be good then.
I bet you have a crappy ground or wire at or near the starter. Use a set of jumper cables as a ground and hot to the starter, turn the key on to run and then hit the hot post on the battery with the jumper cable
So it does crank, then stops. Do this, turn your headlights on, have someone watch the lights while you try to crank the car. If they dim, all of your connections are ok. If they go out, you have bad connections or a bad battery.
I tried again this morning and it won't start but the starter was clicking like it was bad or not getting juice. So I'm betting this is a starter issue, and probably a bad connection. I'll have to wait till after this storm, expecting 18 inches by tomorrow. Thanks for all the replies.
Reactions: Streetbu
The starter starts to click, then just dies. All other electrical functions work. The battery is new.
Reactions: Streetbu
