I tried again this morning and it won't start but the starter was clicking like it was bad or not getting juice. So I'm betting this is a starter issue, and probably a bad connection. I'll have to wait till after this storm, expecting 18 inches by tomorrow. Thanks for all the replies.
I don't trust jump starts they are too unreliable and lots of time people think just hook up the cables and think it will start right away. They don't even give it time to re-charge the cars battery a little before trying to start it again.
Try to find a side post battery, preferred is one that is from a running car and swap it into your car then try again. It definitely sounds like a weak battery or a bad battery connection.Starters don't just go bad from getting cleaned but if water got into the starter motor then a spray down with WD40 will get that out of there.You can also use it inside the distributor cap to dry it out if water got in there.Also just spraying the outside of the plug wires will help get it to start if that is a part of the problem.
Incidentally that's what WD40 stands for.....
Water
Displacement
40.....The 40th try when they were inventing the chemical formula and then finally got it right.
Check to see if the +Pos and -Neg terminals are clean & tight. Follow the cable down to the starter, is the battery cable tight at the starter ? And to make sure it's tight there,You can just give it a good tug if its loose you'll feel it move.
If it was starting before you cleaned the engine the new or temporary replacement battery should get it to start up again. keep us posted.
