I am in the process of building a ZZ430 clone motor. For those who haven't seen this, it is a ZZ4 crate motor with fast burn heads and lt4 hotcam. Anyhow, I have just installed the fast burn heads. I have not installed the pushrods or rocker arms yet. However, before installing the motor in the vehicle, is there a way to check that the headgasket sealed properly, i.e. via compression or something of that nature? This is my first time bolting heads on and while I am confident about the procedure I followed, I would also like to play it safe. I'd hate to button it up, install everything in the car, only to find out it didn't seal properly. I ended up using ARP head bolts torqued at 70ft lbs per the instructions. I went in three passes at 25, 50, and then 70.
