KB pistons 455
bigdan
380
4
st-jean baptiste ,quebec,
bought some KB 277 pistons for a 455 olds ....
no instruction to show how to install these in cylinder
there is flat top portion on the piston top ....
does it go outward or inward ?
as in A or B pic ?
Look at your heads, it'll become clear. 😉
You want the pad on the piston to line up with the pad on the head for quench.
That being said, usually there's a mark of some sort on the pistons telling you which way they go.
If all else fails, you can always call KB.
you are right ! so obvious :roll:
what fooled me is that car craft did an article on a 455 build with KB`s pistons and they show them with the flat part outward`s .......they goofed !
http://www.carcraft.com/techarticles/cc ... index.html
look at the pic where you see the pistons installed !
