Sheesh, I meant Kicker's duh. Should be fine either way.They still fit, just had to gently push them down just the last 1/8" or so to get the screws in
not all of us can be growers and showers..Still, it's only 3.5".
That's what she said!!!!![]()
Geez Steve, you're measuring in cm, measure in mm and it will be 88.9.....way more proud lmao!that why we use the metric system, that would be 8.75 mm.....😎
If your amp is not just used for subs I'd hook them to it using a 2.2 uf non polarized capacitor. Amps in head units usually have higher distortion, which will blow tweeters faster than clean power.Anyone using these?
Any good?
Junk?
They will not have an amp going to them.
Thanks
https://www.amazon.com/dp/B0007LLNWQ/?tag=gbody-20
Not much room to grind on the Cutlass ones, maybe 1/8" tops.There's plenty of meat in the plastic grill. Hit the backside/offending area with a 4" flap or sanding disk in a grinder. Man up.
