Key Release Column Manual Transmission
pontiacgp
blank
Mar 31, 2006
29,270
20,425
Kitchener, Ontario
What have you guys, who have converted to manual transmission, done with your steering column for the key release. I havn't done anything so if I shut the car off the steering wheel locks. I tend not to shut the car off at 70 mph so it's not a major concern but I would I'd like have a key release that comes on column with manual transmissions. I want to keep the tilt steering so getting a column from an A body isn't an option for me. I appreciate any suggestions you guys may have.....🙂
Reactions: Texas82GP
the key release lever you find on a column of a manual shift car.
take the parts from an S10 column and install them on yours they are the same just the length of the shaft and mounting plate are different
I found a few on carpart.com, they are 2000, 2001 and 2002 and they are all tilt so do you know is that version the same length os the G body. One of them is an Izuzu
Isn't 2000-up is the square column?
I know my 98 Blazer had the square column Not sure about the S-10
