ATL Regal said:anything?
What number ECM do you have that might explain the differences in colors of the wiring.
Doober said:Maybe I missed it... why are you tracing down all this wiring again?
Yes. Absolutely. Definitely. Yes.ATL Regal said:Should I get the ecm reprogrammed first, or at least talk to someone that does it about what I will & won't need to make this engine run.
DRIVEN said:Yes. Absolutely. Definitely. Yes.ATL Regal said:Should I get the ecm reprogrammed first, or at least talk to someone that does it about what I will & won't need to make this engine run.
Also, if your donor truck had a Passkey (anti-theft) system, it'll need to be programmed out. Otherwise your car won't start unless the entire system is present and active.
RUDE DOG said:I just compared the pinouts on my truck and its the same exact wiring you have. I am confused why so many discrepancies in the wiring schematics.
ATL Regal said:RUDE DOG said:I just compared the pinouts on my truck and its the same exact wiring you have. I am confused why so many discrepancies in the wiring schematics.
I'ma try to get another wiring diagram from somewhere else. I'll look for the Mitchell one this time.
