I plan on updating my turn signal bulbs to LEDS, what does the LED flasher actually do??? Is it a must to have one just to get the LEDS to work??? or does it just simply keep them from blinking off/on so fast.
454muscle said:The are dull, not as bright, and what's more, many of the so-called "long lasting" LED units are dead withing the clusters. And I'm talking about three people's cars here.
the flasher is located in your fuse panel, under the driver's side dash. It's a round metalic plug-in, it should just pull straight out.
I will try that. I have just one but had it plugged into the pigtail plug insteadMrHernandez said:No, one in the main fuse panel will work for now if you're low on cash
