Torsens don't really "disengage". They are probably the quietest/smoothest of the limited slip differentials.
Generally they are on sports cars like Miatas, Boss 302's and make cornering smoother. The car will feel like the outside wheel is going faster through the corner, reducing understeer under throttle. This allows you to apply throttle before the apex of a turn to help the car turn. This isn't natural and gives car with a torsen a slight advantage on an autocross. Newer active vectoring differentials take this concept even further.
A Detroit locker is the opposite end of spectrum. Brutal engagement/disengagement and in a corner under power it makes the car want to go straight, increasing understeer until it overpowers one of the rear tires and the car oversteers... so you can't apply throttle until after the apex... traditional racer thinking and predictable racer handling.
The downside to torsens is they aren't designed to handle massive amounts of torque in a straight line, so slicks and big HP will blow them apart. 7.5's generally blow apart under these conditions anyway, so it should be fine.
