Looking for a Pontiac 301
Use another Pontiac. You can reuse everything off you old motor accessory wise. Even the tin. There are 2 flavors or Pontiac motors you will come across. Call them early and late. The primary difference is the motor mounts. Early stuff has 2 bolts in the block. Late stuff has 3. You want late. Re use your upper mounts. Not the ones that may come on your replacement motor. Early motors can be used but need a different (read expensive) upper mount. Also, no tall valve covers. The 301 has a shorter deck height. Anything you use others than. 265/301 will be an inch+ taller. Tall valve covers get really close to the AC box. You don't want that pain unnecessarily. Replace you lower mounts while it's out as well.
PS the 301 is not junk, it is mostly the victim of a bunch of compromises. Unfortunately the crank is the weak(est) link. I happen to love my 301.
Yes, and I want to thank you for connecting me with that contact. Engine looks real good. I can't wait to drop it in and see what it really does.
Quite welcome, my man. Now, all we need is a burnout video. 😎
Reactions: Texas82GP
Hooray! Another car was saved from the lameness of a 301. Worst. V8. Ever.
When I was a sophomore in college I had a '79 GP with a 301, 4bbl and the incredibly rare 4 spd manual. Super Cool.
A Senior with a Baja bug challenged me to a drag race and humiliated me. I had a 307 2bbl Malibu Convertible that would stomp it
Even with only 35K miles on it, the valves would float @ 4800 RPM. There are few motors where you can say a stock Chevy 305 would be a huge step up.
Reactions: fleming442
My first Gbody was a 78' GP with what I considered a pretty lame 301 but at least if was faster than the N/A V6 that came in my Regal.
I would have loved to have swapped in a 400 or 455 Pontiac in there.
A 400 will haul *ss. My only experience with the 301 was my friends 79 Grand Prix. Pretty sure it was the 4bbl with the hotter cam, no slouch for that year. Pretty sure it also had dual exhaust. Doug was pushing it pretty hard, he said it started knocking. The 301 Turbo has decently thick mains. Add a real crank with more stroke, no garbage siamese port heads, 301 heads are as bad as Olds 307 swirl port heads for flow, horrible. The hardest part is a decent intake, a small run of single plane intakes were cast, modifying a regular Pontiac intake to fit is a lot of work.
I Miss my 80 Grand Am that had a 400. i will agree will haull *ss.. mine had 373 gears and a locker from a fbody. pass everything but a gas station.
