I'd try a canister first if I couldn't get vacuum up with fine tuning. Much cheaper option and you can still add a pump to the can/booster system if you're not happy and then you should have vacuum for days.
As for the canister, once you close the throttle, vacuum will spike and suck the air out of the canister and booster and as long as the check valve on the canister doesn't fail, you'd have the vacuum you need trapped in the can and booster. Bigger vacuum volume.
BTW, you did check your booster's check valve to verify it's operating correctly? A leaky check valve can cause havoc.
