You just don't throw 500hp plus at it an away you go.
So true!! 700hp plus is the only way to fly!
I'm not sure if they did or not. This truck flat runs though!Did the 2wd 4.8 trucks get a higher stall converter? A guy I worked with had the same truck. It would lay rubber and went like hell. The 5.3/4L70E and 5.3/6spd auto 4wd trucks I drove a lot were plain useless. No doubt the 2wd is lighter and why these motors move in a 3500ish pound car so well.
Yeah, but those aren't "electrical issues" unless they were self-inflicted from incorrect wiring or expecting a 150,000 mile junkyard engine to work like a new crate engine. The sensors are consumables at that point, just like rings and bearings.Honestly? I think you know what l mean. Any electrical components that help run the LS, sensors to fuel Pumps.
I'm not sure about the 4.8s but I know that the Van's and some trucks that came with the 4.3 and 80e had higher stall converters.Did the 2wd 4.8 trucks get a higher stall converter? A guy I worked with had the same truck. It would lay rubber and went like hell. The 5.3/4L70E and 5.3/6spd auto 4wd trucks I drove a lot were plain useless. No doubt the 2wd is lighter and why these motors move in a 3500ish pound car so well.
Aside from my Ford 9in, I did exactly that. I haven't touched my suspension. It's got the same springs from the factory and shocks from who knows when. I know that hurts me in some areas. But it doesn't keep the car from making the power it does.It's not about money to me, its about getting it right, turbos aren't just throw it together and away you go just like in tbe OP, a disaster in my Imo. Can it be tweak, sure but at what time and cost.
Design an knowledge would have help out big time.
Sure you can throw a basket case turbo system together an make it run on a LS it's been proven even on this thread. Doing a Turbo system on a LS just needs to be more proven and consistent #'s.
There is a trickle effect on putting a turbo system in a vehicle whether it be a g-body or not. Up-grades to frame, rearend, suspension and brakes. You just don't throw 500hp plus at it an away you go. So l guess cost does come into and a sh*t load of time.
And for everyone that says "LS swaps are played out",
When you pop the hood nobody usually can see your transmission or rear axle.People could argue the same thing about rear axles too but nobody does, engines seem to envoke pride and brand loyalty but nobody cares about their transmission or rear axle.
