The 5.3 presently sitting quietly on my engine stand is a 2002 from an Avalanche and the throttle body on it is cable actuated; an actual mechanical connection between the accelerator pedal in the cabin and the butterfly in the body. This motor is classified as a Gen II, and the default throttle body for it was mechanical, not Drive by Wire aka (DBW). If I wanted to go fly by wire, I would have to score the appropriate throttle body, along with the module and the pedal assembly. if you have the earlier non FBW harness then there are no wires in it for the DBW.
Spent a week digging around in my local part yard for a year correct matching harness for my mill and most of the harnesses looked right until you got to the throttle body and found the absence of the cable. Don't be confused by the one cable that does attach to the TB, it is for the cruise control.
That aside, would either one of you happen to know of a source for an LS-6 intake manifold/plenum for the 2000-2004 generation motors? They apparently do exist but are on the way to joining the unobtanium list that includes parts like rear brake drum backing plates for the 03 S-10, and Poly-urethane leaf spring bushings for a G-10 and a few other useful items that seem to have fallen by the wayside. Appreciate any leads. THX
