Nothing against your local guy, but if you can tune a carb motor with a dizzy, then you can tune an EFI motor with electronic spark control - just quicker.
The easiest area to make costly mistakes is in the areas of the tune that are not common - going from WOT at redline and directly below that. This area comes into play when you run wide open, dump the throttle for a .5-1 seconds and then go back to WOT. But almost all of it is extremely forgiving until boost comes into play. Other than that, never put more timing anywhere above the 'all in' mark of your motor until the max HP/TQ is achieved.
Hopefully the local tuner will show you the fuel, timing and target AFR tables when he is done. Once you see them and can covert vacuum to KPA it will be relatively obvious what's happenning.
Also, I don't want to sound like an expert, but I I jumped into this about 5 year ago and was very intimidated. But with the help/guidance of one guy I was able to get a good running, safe tune and when I took my 1st EFI motor to the dyno he was extremely forthcoming with info - not everyone is like him - some will try to keep it top secret to maintain your level of intimidation. If you ever decide to have a go at it, then let me know and I'll help with the tables to get it into a safe, driveable tune.
