Ls swap oil pan
Streetbu
Know it all, that doesn't
3,736
11,585
Central NY
Did you get the 302-2 variant? If so take some pictures if you can. I tried the "white box" from amazon and it would not fit at all, the pan was too wide and hit the cross-memeber with my Holley Mounts. The 302-2 "white box" from Holley.com fit perfect and it matched up to my buddies 302-2 exactly without the Holley on the bottom.
FYI Super Shops is owned by Holley that is why the shipping comes in the Holley boxes.
You can read my whole build in my build thread here. I have a huge amount of room around the pan and crossmember area.
Burning
182
647
Bardstown, KY
So with ICT mounts the 302-1/Supershops pan will fit.
With the Holley mounts the 302-2/HOLLEY white box will work. I am verifying if the Summit/Moroso 7qt pan will fit the Holley mounts.
The problem is there are so many variants of engine mounts/pans to use that what works for one might not work for others.
