Ls swap power steering
You can do anything you want its your car. If your having trouble figuring it out I would do what turbolq4 stated and bring it somewhere have them tell you whats wrong and go from there.
So back to the power steering. If i got one would the stock bracket and everything be fine?
So a stock truck bracket? They work if the engine is set back far enough for the pulley to clear the steering box. I have the stock truck pulley as well, some have swapped them out to a smaller diameter but mine worked as is. Not sure where your alternator is located but these brackets put them top left.
