Ls swap
The inlet and outlet are different sizes on the Ls from a sbc so you would need reducers unless you get an Ls specific radiator. I am going with a Griffin Ls swap one, but an LS1 camaro unit could probably work.
So far from what I've been told on here and lstech what I'm going to need are
Engine mounts
Headers
Coolant reducers
Transmission crossmember
Ls style stall converter
Possible ac pump pulley
Can you think of anything else I'm going to need? If I go fuel injected will I need a new fuel pump?
Engine mounts
Headers
Coolant reducers
You will need a fuel tank from a fuel injected 4.3 v6 monte or an efi turbo 3.8 buick. Summit sells an efi Ls swap fuel system kit.
http://m.summitracing.com/parts/cmb-03-0260
This is the first I am hearing of a actual tank replacement, From what i have seen so far is that a aftermarket fuel pump and filter will do the trick.
What is the purpose of a New tank?
