On the other hand, you could always turn around and invest the money it would take to build an LS motor, and build a turbocharged SBC, i've seen some outright just to the moon wild results going with that combination + fuel injection...
CamaroAdam73 said:Budget is always the major factor, but this guy didn't spend that much more than i did. He bought his turbo setup used, bottom end was new, but heads intake..ext STOCK.
You can't easily bolt an older trans to one of the newer LS motors can you?
CamaroAdam73 said:Qdub, that's badass.
Also your looking at like 3000$ in heads to put aluminium heads on a BOP 455. That's JUST in heads, 3000$ would go allot farther with most other builds. As far as i know, either RHS, or edelbrock are the only two options for aluminium heads on a BOP 455, i've looked into it already and went with a stock set because of price for my SBO.
