LT1 engine mount help
Both the mounts on the frame and the engine should be positioned the same as I remember. The frame mounts only use 3 holes and should be directly across from each other. There is usually a wide tab in the rubber insert that should be at the bottom. If the engine mount is upside down, I think you have it in the wrong position.
Ok thanks for the info I will check the block again to see if there is another position to mount the passenger side bracket
