I didnt even think about that part, i may have to pull the other one off and wrap itI'd wrap the other side similarly
you could always mount the ball on the bottom of the fender well under the battery. plenty of room there for that.Actually, I think I’ll move the vacuum reserve ball over to the drivers fender well. It’s no problem running a vacuum line across the firewall. This will allow me to spread the other components out a bit and make room for a batt + and batt - terminal blocks.
I’m not trying to win any awards for appearance but I want a clean reliable wiring plan that’s easy to access, diagnose and work on.
is that set up originally for a b body or what? i'm interested in more details. i have an unused vortech sc. was meant for a 94 f body that mounted the sc down low on the drivers side. would love to mount it up high like the pic shows, so i can avoid the steering gear on a g body.Supercharged LT1 swap here
I'm running a 93 f body motor with a pieced together mount. Don't want to hijack the op's thread , but if either of you need anything message me
