hey
the car is close to perfect when starting, however i think it will take a little more cold adjustment to get this choke pull off working like new.
It fires up ok, however i have to pump the gas a little to keep it going until it stays going on the choke. It runs fine on the choke until i tap the pedal and it releases. Sometimes it seems to run a tad too low and stall, however when its completely warm it works fine. I am guessing that the pull off is needs to be set to open just a little bit more to keep it running from cold.
Does anyone know the correct procedure for doing this, i don't want to screw up the already near perfect settings. Thanks.
