This may be moot/may have relevance, I'm by no means a subject matter expert...read through this entire thread with no mention...off the top of my head, I know of 2 clutch fork ball studs that screw into the bell housing, a standard height and one that is known as a "truck pivot ball" that is .300" taller than the standard. Measuring from the top of the pivot ball to the back of the engine block, a standard bell housing depth should measure 4.75". Any deviations could be corrected with an adjustable ball. I know my Lakewood scatter shield measured 4.85" and add in the block plate ~.120 (I need to measure this to reverify) but this .220" is what prevented me from getting a complete disengagement at the bottom with pedal play or adjusted the other way full disengagement but no pedal play not to mention shifting issues. Although not perfect, it was the .300" taller pivot ball resolved that issue. Another thing that comes into play is the standard thickness flywheel of .960". Varying the thickness is probably the easiest way to a light/heavy flywheel but does affect the 4.75" dimension as mentioned and can be corrected in the same manner. Thinner add and thicker subtract from height of pivot ball. All this should be done prior to installing but one can just assume if you're using all oem parts. I have no experience with the rhyme or reason for tall/short TOBs but I'm all ears.
