Manual swap, with a twist!
marcar1993
702
209
New Jersey
So, I'm now assembling parts to do my manual swap. I just ordered my John B pedal, I plan to run a 3rd gen clutch master and either a slave or HTOB, depending on how things go. Here's the twist, I'm running an olds motor. All the info I find for these swaps is with a sbc. SO, on that, here's where the questions begin. I know I need to drill out the crank and get one of those adapter input shaft bearings. I know a t5 will bolt to any 4 speed bop bellhousing, but will the stock slave still work? What about a t56? What do I need to do to mate a t56 to a bop bellhousing or run an adapter plate to mount the stock chevy bellhousing to an olds motor? Then I need a spacer for the flywheel? What does that do to my starter engagement?
Any help is greatly appreciated.
Thanks,
Martin.
Ok, so now what else do I need to make that function? No flywheel spacers? No lengthened input shafts? What about hydraulics? Can I still use the stock slave or do I need to run a HTOB?
I have not done that installation but I imagine all the parts you need would come with the adapter for the price they are selling it for....as for the throw out bearing I have no idea but the T56 uses a pull slave. I'm sure the company that sells the adapter would have that info
I'm honestly not sure yet, it depends what trans I find, but from what I understand an lt1 trans would be easier, so thats what I'm shooting for. In the event that I run an lt1 trans will an ls1 tob just slide in place?
If you're buying an aftermarket htob then you can use either t56 (ls1 or lt1). Keep in mind though the lt1 has a shorter input shaft than the ls1. That might actually help you out if your just doing one of those conversion input shaft bushings in the crank.
For a bell housing you can look into McLeod. I have one of their modular bell housings and everything bolted up really nice to the 455. However they are not cheap.
If you go with a htob you can use the clutch master cylinder and push rod from an LS1. Earls then makes a fitting that let's you get rid of the stock braided line and install an aftermarket braided line with AN fittings.
Thanks, I was leaning towards the lt1 t56 for that reason. I thought that the ls1 t56 needed some mods to work because of the input shaft length? Which one are you running in your car?
I LT1 version but if I were to do it over again I would go with the LS1 for the longer input.
If you actually drill the crankshaft out to use a real bushing then you can run the LS1 trans without any problem. I had my crank drilled to the factory specs for a manual trans car but since I have the LT1 trans I had to use an adapter bushing (included with the Mcleod bellhousing I bought) to support the LT1 input shaft.
The LS1 input is actually closer (if not the same length) to the old Muncie/T-10/etc. manuals.
If your rebuilding the trans I believe you can convert the LT1 over to the LS1 input shaft but I haven't looked into it. The nice thing about the Mcleod housing is that you can use either transmission with it. The bushings for the LT1 is the only difference.
So, would the lt1 trans fit without drilling the crank then? And whats wrong with using the adapter bearing? Is there a downside to it?
