My brakes leave a lot to be desired especially considering the parts
The front brakes are discs with ssbc dual 38mm piston calipers and rears are factory style drums with new factory wheel cylinders.
The brake fluid is all new and lines are newer however the pedal seems to have quite a bit of travel before actual braking power and under panic braking you essentially have to bottom the pedal to get any worthwhile brakes.
Do I need to upgrade to the larger bore masters?
I’m probably not going to do the right hand drive blazer but I could potentionally do the Electra wagons master. Would I benefit more from a different master cylinder or do I not even need to upgrade?
I obviously also want the best booster I can get I currently have the 83 factory so I’ve read a bbody one could be an upgrade but I’m not sure the information on these swaps is kinda all over the place
Thanks for the help
Thanks for the help
