That was for the change to the dual bore type needed for the new "low-drag" metric brake calipers. The parts are still interchangeable.78-80 uses a different master than 81- and up
I want the screw on cap for ease of maintenance and less mess. I check fluid every month before I go racing and the current reservoir is not see through. Plus I have to change the master so why not upgrade at the same time.I can't see a reason it wouldn't work. But he says he wants a screw-on cap. I don't see the big deal about that. It is a little harder to R&R the big cap but it's not like it needs to be done very often since you don't need to remove the cap to check the fluid level.
I’ll see if that is readily available at the part store so I can swap out under warrantyI think the ACDELCO 18M974 should do it for you. 1" bore with 1/2" and 9/16" fittings
Application is a RHD S10 pickup.
