Master cylinder for Blazer brake upgrade with C5 fronts and (stock drum rears) 12/18-upgrade to rear disc
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
no such thing as overkill when it comes to the brakes
Reactions: 4 users
roger1
537
767
San Angelo, TX
Would this be Overkill for a stock set-up?
Not trying to de-rail the OP. Just curious for informations sake?
Stock setup is 15/16" bore. '81 and up is a step-bore 15/16". The short larger bore (I think about 1 1/4") is to take up the slack in the low-drag metric calipers before they apply pressure to the rotors using the smaller bore.
Tomeal
919
1,632
Clyde,pa
So would the foot feel a difference?
nomoar
14
Has anybody used the ACDelco 18M974 with the 12" dual diaphragm booster (b-body booster upgrade)?
64nailhead
Goat Herder
Dec 1, 2014
5,709
12,216
Upstate NY
78-80 uses a different master than 81- and up
^^This is what is needed to be known to determine master cylinder choice IMO. If I would've known this at the beginning of the upgrade, then I would've struggled much less.
If you know what booster you have, then you figure out which master cylinder will work.
I want to pass it along that I don't believe that I can get better braking than what we have with stock components - the Riv master works great with the disc upgrades we installed. This thing will stop like a new, modern car presently. After putting the C5 fronts I thought it was night and day, but after the rear disc and master cylinder upgrade it is waaaay better. I would recommend the Riviera master to anyone that has an '80 and earlier booster.
