Mcss floor shift help
NorthWestRider
301
70
so last week i scored a console and shifter for my mc my question is i need the brackets to the cable that bolt to trans so i was do n some research and im seeing that there still some linkage rods that go to the trans selector where the cable hooks up what are thos for ?
NorthWestRider
301
70
12,176
9,795
NorthWestRider
301
70
What trans in there currently? Your trans cable bracket doesn't look right. The linkage rod from the trans lever goes to the column shift arm in the engine compartment. That doesn't look right either.
They probably have what you're looking for.
http://www.dixierestorationdepot.com/Product/Browse.aspx?d=1083&p=1
Actually this is not my trans pic i found it in a search but did a search to see brackets i needed and seen a few pics with the linkage rods and cable i did notice when i pulled the column from the car it had a rod go n to end of column
NorthWestRider
301
70
The car i pulled the console from had the trans already removed so wasnt sure if other than the bracket that holds the cable if i was missing anything else
12,176
9,795
I was wondering if that was your setup or not. That one looks like a mess.
Just make sure you get the right bracket for the transmission you're using. The one for a 200-4R is different than the one for a TH350.
What transmission is in your car now?? The reason I ask is because a 200-4R uses a different cable than a TH350. ..ask me how I know.
NorthWestRider
301
70
Th350 can u send me a pic or link of the braket i need if possible
12,176
9,795
I'm assuming the shifter was from a later Monte Carlo with 200-4R. If so, you not only need the cable bracket that goes to the pan, but also a shift cable for a TH350.
I currently have a 200-4R shifter in my car connected to a TH350. It works okay, but the gear selection is a little soft. In other words it goes into the right gears, but you don't feel a positive click.
You can purchase the new cable from RockAuto...and check out the link I sent you for Dixie.
That's where I bought the cable bracket.
You can try reusing the cable boot from the other cable. They don't supply them with a new cable.
Here's the link to the bracket. http://www.dixierestorationdepot.com/Product/Detail.aspx?s=DM00414&d=1083&p=2
